Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Where is example source code for ST33TPHF20I2C?
Apologies if this is the wrong 'Topic' for this chip.I'd like to find source code and other details on using this part for RSA signing, also I'd like to know how to use the on-board NV memory.The data sheet does not seem to have sufficient informatio...
SBern.6 by Associate
  • 1069 Views
  • 0 replies
Resolved! Datasheet for ST 324BAAP microcontroller
I am looking for a full datasheet for ST microcontroller 324BAAP 269-546 9911L V5 MYS 145. Do you know if I can find anywhere or is any way to ask ST to provide this? Thanks in advance for any help.Zygi
rachas by Associate II
  • 3196 Views
  • 6 replies
1) What is the difference between ST232A and ST202? The pin out and all data seems to be identical, but ST202 seems to be slightly cheaper. 2) Is it possible to use only the switch capacitor inverter, but not the voltage doubler?
I want to utilize the very low power supply current of typical 1.5 mA to make a galvanic separated RS-232 interface, which is driven by RTS and DTR (trough two diodes) on the RS-232 side. The plan is to connect the cathodes of the two diodes to V+ an...
CKans.1 by Associate
  • 1010 Views
  • 0 replies
blueNRG uart ble Emulation UUID
I want to use a blueNRG to avoid the cost of bluetooth SIG registration, because I would be able to cover the cost with my product. In addition I want to use ​similar to nordic semiconductor a uart ble emulation as service (https://infocenter.nordic...
YGail.2 by Associate III
  • 1338 Views
  • 0 replies
any switcher IC like/similar IC u3843 that can take I/P 40 to 60v dc and we want to convert this volt to 5v dc
any switcher IC like u3843 that can take I/P 40 to 60v dc and we want to convert this volt to 5v dcwe have tried these circuits have a look at this drive link https://drive.google.com/open?id=1MhtkH4kwJYyro00IqTu6guRDOnfzlo0-&authuser=narendra%40sixs...
ashutamar by Associate II
  • 1149 Views
  • 0 replies
aci_gatt_add_serv returns out of memory
Can you increase/allocate more memory to a service? How do i do this?The first 3 services I add have no issues. When I add the fourth service I have a ret of 0x1f(out of memory).ret = add_live_group_service(); ret = add_config_calib_service(); ret = ...
DKopp.2 by Associate III
  • 1159 Views
  • 0 replies
