Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Resolved! P2PRouter can't get server accelerometer data
Hello everyone!I have succesfully connected my p2pRouter (it is a STM32WB5x) to a p2pServer (always STM32WB5x). On the Server there is an IMU and I want to send data from server to router via bluetooth.If I connect my phone to the server with STBLESe...
Erica1 by Associate
  • 1338 Views
  • 1 replies
BlueNRG UART bootloader: 'go' command question
Hi,Based on AN4872, I managed to get the id, version, erase, read and write memory commands working. I'm able to erase the entire flash of a BRNG-M2SA or BNRG-M2SP and write a pre-built example bin file to the flash and read it back, without errors.H...
Wingunder by Associate III
  • 1889 Views
Regarding the thermal data for the parts.
Hi team, Kindly assist us the below mentioned queries.For the some ST microelectronics part data sheet, can not specify the thermal parameter such as junction to case thermal resistance and junction to board thermal resistance. we need those values f...
L9663
Direct interface of communication interface Is the transceiver directly connected to the PSI5 interface of the ECU
JL1 by Associate II
  • 1140 Views
  • 1 replies
BlueNRG-LP beacon example not discoverable
Ive been trying out the different examples on the navigator, and have noticed when using my ble scanner, my device cannot discover the beacon example. I have compared the code with the sensor example which is discoverable and they are very similar ap...
100Vref by Associate
  • 1214 Views
  • 1 replies
