Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
S2-LP Parameters configuration
Could someone help to understand the better value to use at frequency deviation, considering at bellow specs:   #define BASE_FREQUENCY 916000000 //Hz #define MODULATION_SELECT MOD_2GFSK_BT05 #define DATARATE ...
LPrat.3 by Associate II
  • 1302 Views
  • 0 replies
Resolved! S2-LP - Interrupt flag problem
Hi,Some time ago I wrote a software with some changes from this library and successfully tested it with the STEVAL-FKI868V1 board and a ST board (STM32F779 EVAL).Now I made my own hardware with a little changes in the microcontroller pins. Communicat...
Slh by Senior
  • 1655 Views
  • 1 replies
Resolved! Write SD card using bluenrg 332ac
Hi,I am trying to write the IQ data to the SD card (i.e., write the received CTE pkt to the SD card). However, I found that Bluenrg-332ac has a cortex M0 core, which may not be able to drive an SD card. Is it possible to use this cortex M0 core for S...
JasonYang by Associate II
  • 1735 Views
  • 3 replies
  • 2 kudos
