Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Balun options for BlueNRG?
I'm using BlueNRG132 (QFN32) in a custom PCB project. Currently I'm using BALF-NRG-01D3 chip, but I would like to know if there are other options of Balun Chips to use with BlueNRG and 2.4 Ghz (50 Ohm matched) antenna. On the other hand, I would like...
FHern by Associate
  • 767 Views
  • 1 replies
How to implement resolvable and non-resolvable private addresses in the BlueNRG-2 module using Keil?
Hi, i am new to using ST boards. I am using a broadcaster which only sends data after every particular interval. I want to use resolvable and non resolvable private address techniques to secure the data sent and direct it only a particular user and n...
I want to take images from a CMOS camera and wanna send to a mobile phone, It is clear that DCMI offers perfect solution to get images but I could not find any sufficient way to send images to a mobile phone via wireless communication.
More spesicifly , I could not calculate the data size for every image and I am not able to determine which wireless communication protocol for mobile phone suits to my project. Would you guys give me clue,reference or idea?
NUCLEO-L476RG with I-NUCLEO-LRWAN1 time out
Dear all,I have 2 NUCLEO-L476RG with 2 I-NUCLEO-LRWAN1 lora shield.I plug the shield on the nucleo, connect the antenna, connect the nucleo on my computer, and I compile and load the ping_pong demo program sx1272mb2das from "en.i-cube_lrwan" into eac...
jarjar by Associate
  • 1915 Views
  • 4 replies
SPBTLE-RF0 Bluenrg-ms Max_Attribute_Records
Hello,I want to know about how to calculate max attribute records when I want to add server ? Is there a limitation of number of servers or characteristics ? If there is a limitation about characteristics or servers number, how many byte or number?Th...
MKara.10 by Associate
  • 620 Views
  • 0 replies
SPIRAW Function of S2LP-SFX-DK
Please let me know the SpiRaw function data format in S2LP-SFX-DK. in_buffer [0] - 0x00 is SPI Write, 0x01 is SPI READ, 0x80 is Command in_buffer[1] - SPI Reigster Address or Command in_buffer[2]~ - Write Data
CKim.18 by Associate II
  • 1673 Views
  • 3 replies
