Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
STMF446RE nucleo I2C interface does not work. This maybe a wery dumb question but how do i get my I2C to work? the initialization is created using cubeMX, after that i am just using the hal function HAL_I2C_Master_transmit().
So the details of the configuration are: i am using I2C3 peripheral with the clock speed of 100kHz the pins are set to open drain no pull up no pull down. I am also using external pull up ressistors.I have already checked the internet for a solution ...
BMave.1 by Associate
  • 768 Views
  • 0 replies
S2LP and CC1101 compatibility
It's the first time that I have to set RF modules.I have the following RF modules: S2LP of ST and CC1101 of Texas. I need that they communicate togethar. Do you know if they are compatible?I know that in the module C1101 you can select 2GFSK modulati...
SGior.1 by Associate
  • 1873 Views
  • 1 kudos
Resolved! right subGHz radio modules and their range
Hi,I am trying to use subGHz RF modules in my design. I have following questions. It would great if any one could answer these questions. I am trying to build sensor nodes + Gateway. Planning to use mesh over sub GHz.What is the difference between S2...
Debugging the STEVAL-IDB011V1 via CMSIS DAP
Hey all, We received our evaluation kit in the mail today and I'm trying to get some "Hello World" projects running. I'm using IAR 8.50.4 and have had success flashing the example projects to the board using the Navigator and by dropping Hex files in...
DWeie by Associate III
  • 1328 Views
  • 1 replies
