STM32CubeProgrammer (MCUs)
Ask questions on STM32CubeProgrammer and find answers on device detection, connection failure, programming issues, and more.
Resolved! STM32CubeProgrammer v2.22 released
We are pleased to announce that STM32CubeProgrammer 2.22 is available What is new in 2.22: Support for the STM32U3 microcontrollers with 2 Mbytes of flash memory: Internal memory programming through debug and bootloader interfacesOption bytes program...
Resolved! CubeProg 2.15 Register view bug
Hi!I am working with CubeProg 2.15 and a STM32H743XI. When using the register view window with peripheral ImpDef there is bug in the register addresses: ITCMCR is correctDTCMCR is correctAHBSCR 0xE000EF90 (0xE000EFA0 would be correct) -> content of I...
GR by Associate
  • 1230 Views
  • 1 kudos
Resolved! Cannot make STLINK v2 connection with STM32WL33
Hi ,I am using STM32WL33 in my design and just received my first PCB assembled.i am trying to flash the board with basic program but no success yet , it would be great if you can help to find the problem.i have tried with both CubeIDE and Cubeprogram...
KarthikGo_0-1739485547936.png KarthikGo_1-1739485560267.png KarthikGo_2-1739485567705.png KarthikGo_3-1739485977860.png
STM32H745ZGT6 Unable to Connect
I am using the STLINK-V3SET. I have tried both the JTAG and SWD headers. 10:03:14 : UR connection mode is defined with the HWrst reset mode10:03:15 : ST-LINK SN : 00260035353251103133343010:03:15 : ST-LINK FW : V3J15M7B5S110:03:15 : Board : STLINK-V3...
bmorse by Associate
  • 1390 Views
STM32CubeProgrammer cannot connect to USBX DFU
Dear All, On my NUCLEO-U575ZI-Q I have successfully generated USBX-DFU and have come to a point to connect to it with STM32CubeProgrammer. It seems to be very simple, there are six callbacks only:USBD_DFU_Activate and USBD_DFU_Deactivate does not ret...
DmitryR by Senior
  • 994 Views
  • 1 replies
Resolved! STM32CubeProgrammer rocky8 linux launch issue
After Install launching returns CubeProgrammer_API is missing. Please try reinstalling or check you java architecture. Ive seen some other forum posts with this issue and tried to fix the java version to no avail.Current java version is java-1.8.0-op...
re24 by Associate
  • 3669 Views
  • 7 replies
  • 2 kudos
