Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
LD1117 Input & Output Capacitor requirements
I am currently designing a circuit using the LD1117S50CTR.In the recommended circuit in the datasheet, Cin = 100 nF and Cout = 10 µF are specified.For an LDO, I believe Cout is critical, while Cin is not as important.Therefore, I am considering using...
Matsuura by Associate II
  • 1100 Views
  • 8 replies
  • 1 kudos
Example Code for VNF1048F
Hello ST Community, i have problems to get the VNF1048F chip to run. It goes every time to the fault state and can not find out, why this problem occurs.The documentation for this chip is not really good and there is not sample application (Source Co...
Markus_W by Associate
  • 1322 Views
  • 4 replies
  • 1 kudos
VNF1048F & VNF1248F SPI Communication without VS
Hello, We are developing a design around VNF1048F & VNF1248F products.  We are considering a multichannel design with different output settings. In a multichannel design, naturally we are expecting to have control and monitoring capability of individ...
zekasi by Associate
  • 188 Views
  • 0 replies
VNF1248F & VNF1048F Functional Safety
Hello,We are developing a design around VNF1048F & VNF1248F products. From the other community posts, we learned that VNF1048F has ASIL - B for functional safety rating.We would like to confirm this information, and we also would like to know if VNF1...
zekasi by Associate
  • 209 Views
  • 0 replies
L6494LDTR
Hello I am using the L6494(14PIN) as a driver for a high and low side FET in a half bridge arrangement. My DC volts can be anything from 120Vdc to 220Vdc. and current up to 17AIs there anyway to determine the breakdown mechanism if I do not momentari...
camabe by Associate
  • 2049 Views
  • 1 replies
EVLVIPGAN65DF radiated EMI
EVLVIPGAN65DF application note states that the provided reference design is compliant with IEC55022 Class B conducted EMI. How about radiated EMI? Is there any measurement in this regard?
Gaston by Senior
  • 594 Views
  • 4 replies
Resolved! L6982CDR application problem.
Hi,We're encountering an issue with the L6982CDR buck converter in our application. Here's the detailed scenario: Configuation: We're using it to convert a 24V input to a 5V output to power the board. Load: The 5V output supplies a load current of ap...
PL3 by Associate II
  • 1607 Views
  • 12 replies
  • 1 kudos
Resolved! ST Products website
I don't know what happened recently (or perhaps longer) with the ST website, but where can I find the ST products?
maniek by Associate III
  • 537 Views
  • 3 replies
  • 2 kudos
In need to replace a resistor diode
Greetings, I have being searching for this diode but I had no luck. Markings: BEX 6BA (SG)?)This is an electronic control module (ECM) 12v for an ATV 2007 Polaris 450. I am trying to fix it and I need help to buy this little piece. Any help will be a...
frwycop by Associate
  • 470 Views
  • 4 replies
  • 2 kudos
