2025-05-04 11:09 PM
Hello ST community,
We are working on a 15kW Rectifier module for EV charging application. This module contains 15kW Vienna rectifier and 12kW DC DC converter, input voltage: 3 phase 415V, output voltage: 40V-120V.
For this requirement, we are exploring project files (Altium files) and application notes around this power range. If you could please provide these documents, we greatly appreciate your support.
Akash.
2025-05-04 11:35 PM
The same statement applies as in your previous thread: For many reasons, this power class is somewhat above what can be discussed here in the community. I therefore strongly recommend contacting your local distributor.
/Peter
2025-05-04 11:35 PM
/Peter
