L9963E cell balancing
Salvatore1996
Hello.
I have a problem with this IC. I can read cell voltages perfectly. but when I initiate cell balancing on selected cells, its not happening. for that I follow these steps:
1- I enable cells by writing on 0X1C Register.
2- I set UV threshold by writing on 0XB register.
3- activate manual cell balancing by writing on 0X4.
4- then Select cells that need to be balanced by writing on 0X10 & 0X11 registers.
5- and last initiate balancing by writing on 0x3.
but the balancing process will not start.
I appreciate any help.
0 REPLIES 0
