TS4061AICT-1.25 marking
Chris118
Hallo,
how do I know what marking TS4061AICT-1.25 has?
There is no hint in datasheet.
Can you help?
Peter BENSCH
The markings of the devices are usually internal information and are rarely mentioned in the data sheet. However, the same markings can also be found on the box label.
/Peter
5 REPLIES 5
Peter BENSCH
/Peter
I'm sorry Peter, but that does not make sense. In my experience, most datasheets actually do list the device markings. Just take a look at some of ST's own datasheets, like LM4040, TL431, TS821, etc.
Hi Peter,
if we only need small amount of device we do not get a full reel. So the box label is missing.
Furthermore, who guarantees that the correct component is in the box?
It would make things much easier if marketing is mentioned in datasheet.
So how do I know which is the marking of TS4061AICT-1.25?
Regards Chris
Unfortunately, you cannot generalise this observation: STMicroelectronics reserves the right to treat component markings as internal, non-official information. The different divisions treat this differently, so that sometimes you will find markings in the data sheet, but in other cases not.
/Peter
Hi Chris,
The respective supplier guarantees the correctness of the correct component in the box/bag/reel and must also answer any further questions.
/Peter
