STM32 MPUs Embedded software
HUK on STM32MP135F-DK
HelloI read the article related to HUK. However it seems it does not explain how to use the HUK for STM32MP135F-DK.On STM32MP13xC/F lines,STMicroelectronics provisions an HUK in the OTPs. These OTPs cannot be read with the BSEC IP. The OTPs storing t...
syedelec by Associate III
  • 254 Views
  • 0 replies
Stm32 mp1 Dev/tty/msg
Hi, I'm reading up on stm mp1, in particular the Linux side, my intent was to use the M4 to read data from sensors and transfer them to the A7 on the Linux side. Now I've read the function in C code that reads the messages from the manual: read:int r...
SDall by Associate II
  • 382 Views
  • 0 replies
STM32MP1 TPM event logs for TF-A/OPTEE
HelloI hope you are doing wellI read the TF-A documentation and I found out that there is a POC for TPM service that measures event logs during startup. Source: https://trustedfirmware-a.readthedocs.io/en/latest/design_documents/measured_boot_poc.htm...
  • 3667 Views
  • 1 replies
Resolved! Cant Compile Yoct
Dear All, I have followed the instruction as per Intro to Embedded Linux Part 2 - Yocto Project.The compilation for layer kirkstone. When i run the command "bitbake core-image-minimal" it give error after 4 hours of work.The error is pasted below./ho...
apkumar by Associate
  • 760 Views
  • 1 replies
  • 1 kudos
