Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
BMS using AEK-POW-BMS63EN
Hi,New to the community here.I am new to using this BMS evaluation board AEK-POW-BMS63EN. I want to connect a battery pack to this and an external microcontroller to receive the digital data and do something with it.So a battery pack as input to this...
shafkat by Associate II
  • 1973 Views
  • 3 replies
Resolved! Looking for a low Iq (e.g. 1uA) eFuse
Hello,I looked through the data sheets of multiple efuses and cannot really find reliable values of Iq (quiescent current) values (somtimes only leakage for certain pins is given). Even the product selector does not show any listings of Iq. Every oth...
Andir by Associate
  • 1330 Views
  • 1 kudos
Grid tie based solar inverter reference designs
I am in the process of designing a new grid tie based solar inverter.i am designing it for a load of 1650w approx.Please share some technical documents and reference designs to start my design mainly from STMicroelectronics.
Amal Babu by Associate III
  • 1396 Views
  • 1 replies
Resolved! STDRIVE101 PWM Output Jitter Inquiry
Hello Team,I am planning to use the STDRIVE101 to develop an ESC, and I would like to clarify something before proceeding.Does the STDRIVE101 introduce any jitter in the PWM output? If so, what is the typical jitter value?Thank you for your help.Best...
ajietb by Associate II
  • 940 Views
  • 1 replies
Resolved! STGAP3SXS datasheet need correction
InSTGAP3SXSdatasheet is funny table , input -> output state, the most important thing for a driver - but wrong:btw : 1. Do not care.   -- is perfect here.
AScha.3 by Super User
  • 1309 Views
  • 1 replies
  • 2 kudos
Resolved! Unconventional use of L9826 (erroneously before L9925)
In my project I use a L9826, 6 Outputs are used conventionally 2 outputs are not used. In the same project I need to have 2 digital inputs (SPI) and I would like to know if I could use the two unused outputs of the L9826 as HCMOS inputs via the Fault...
Fred4 by Associate II
  • 2272 Views
  • 5 replies
  • 1 kudos
