Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! TVS bidirectional diode
A TVS bidirectional diode labelled as GMK GP401. What would be the value of the TVS diode? Thanks
Hercules by Associate
  • 1719 Views
Why does the LD39050 have a maximum capacitance value?
We have been seeing some intermittent failures of the LD39050 in our products. I can't see anything wrong with the design other than the output capacitance. The datasheet specifies a maximum of 22uF for stability, but our design has approx 30uF on th...
MAlde.3 by Associate
  • 1117 Views
  • 1 replies
Resolved! EVLPOWERSTEP01 Board Bill of Material & Technical Queries
Queries:1. Could you please provide us manufacturer part numbers of all parts/components used on Evlpowerstep01 Board.2. Provide shunt resistor 0R1/2W tolerance value.3. Provide all decoupling capacitor type?4. Value of Capacitor Cp used on evaluatio...
STPD01 Configuration After EN or Vout Change
It looks like I need to write ILIM after making a change to Vout unless I want the default value for 500 mA. I didn't see this mentioned in the datasheet. Are any other settings affected by changing Vout? What about de-asserting and re-asserting the ...
