Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
It appeared that nobody answer on spv1050 questions.. I had same problem as ask before : could not activate ldo if there are no charge ! even if battery is full! This is crazy! Also boost buck not working as expected.
Well, I have a lipoly single cell and ixolar solar cell from iXys (Vmpp = 4.3v) connect to the spv1050.Buck boost not working correctly, efficiently is worst bad. (I got onlt a fraction of Amp from a direct connection to my battery!)it is impossible ...
Efian.1 by Associate II
  • 1252 Views
  • 3 kudos
CS pin information
I suceed to have information on CS pin like short to VCC, Loss of GND. I havn't information like open load detection, or short to ground.I For open load detecion : I use external pull-up resistor Rpull_up as describe in datasheet and the motor driver...
MEVAN.1 by Associate
  • 675 Views
  • 0 replies
How to tune/tweak STWBC-WA settings using the STEVAL-ISB045V1 board to work with a Qi compliant, TI receiver (bq5105xB)?
I have a design that uses the STWBC-WA on the TX board and a TI BQ5105xB chip on the receiver side and I'm having a hard time getting the handshaking and charging to work. I am using the STEVAL-ISB045V1 with the Tx coild swapped out with the coil we ...
DCamp.1 by Associate
  • 2191 Views
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
