Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! What is 'minimum RMS current' in STPM32 datasheet?
Hello,I'm working with the STPM32 and I don't understand what I MIN (also referred as resolution) is (Equation 27, page 79 of DS10272 Rev 8).Why if the data is provided in the registers with 17bit resolution, the calculated RMS current resolution is ...
DGiov.1 by Associate III
  • 1354 Views
  • 4 replies
Diode identification
I have a diode that I am trying to identify. Its markings are:ST e3ZTTH (the 'Z' is backward)112230Anybody know what it is and what can be used to replace it?
RSton.1 by Associate II
  • 1654 Views
  • 3 replies
Resolved! L6206Q Charge pump circuit.
In the L6206Q data sheet "Figure 5. Charge pump circuit", AN1762 APPLICATION NOTE "Figure 9. Charge Pump", UM1925 User manual "Figure 11: X-NUCLEO-IHM04A1 circuit schematic", the connection order of Rp and Cp is different. ..In actual operation, the ...
TYOSH.1 by Associate
  • 1171 Views
STEVAL-ROBOT-1 MODBUS baud rate. How to increase the baud rate from the factory 19,200? Currently stops working at 38,400
I tried changing the baud here in main()static void MX_USART1_UART_Init(void)huart1.Init.BaudRate = 57600;and here in mbtask.c:void ModbusRTUTask() eMBErrorCode eStatus = eMBInit( MB_RTU, MB_SLAVE_ADDRESS, 3, 57600, MB_PAR_NONE );As mentioned, this o...
Liam G by Associate II
  • 3193 Views
  • 6 replies
FAQ_STC3117
1. What is the different between STC3115 and STC3117?STC3117 is an improved version of STC3115.See the differences between both parts in the attached document. (STC3117_vs_STC3115_comparison.pdf)2. How often is measured the temperature?STC3117 measur...
