I have made a circuit using ST1S14 IC and i am unable to get the desired result. I want Iout to be atleast 1A. Can you help?
PKuma.1
IMaka.1
What are the properties of your inductor? I faced a similar problem. My design limits current (stops generating pulses) with a load of about 2A. Think it goes into hiccup mode, but its peak current is much lower than 6.2A noted in datasheet. Maybe it is an overtemperature shutdown, but the temperature of the chip never exceeded 60...
