Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
VND5E006ASP-E Max Voltage Output for CS pin
To confirm, the max output voltage on CS pin (I assume it is called VSENSEH) is 8V according to Table 8 on p11 (https://www.st.com/resource/en/datasheet/vnd5e006asp-e.pdf).  But I assume this depends on the sense resistor and ISENSEH of 7mA.  What is...
jsmith by Associate II
  • 1383 Views
  • 1 replies
Resolved! STPS3045CPI Obsolete - Common cathode doubt
Hi,STPS3045CPI is now obsolete and STMicroelectronics no longer carries collateral support. I am wondering if anyone can help. I am looking thru old documentation but it is not clear to me whether the mounting plate on the top is connected to the com...
ManuelDS by Associate
  • 1833 Views
  • 1 replies
Resolved! STPM3x INT1/2 outputs - how to configure
hi,I am now familiar with the STPM3x programming, by using EVALSTPM33/34 boards.I have been able to do some basic low voltage testing where I receive interrupts on INT1 line on EVALSTPM33/4 for voltage swell before I try mains voltages.Then I run the...
PaulL by Associate
  • 1220 Views
  • 1 replies
Resolved! Use of powerSTEP01 in “voltage mode�?
We are developing an OEM board which is capable of driving bipolar stepper motors from 15 to 80Vdc 10A max, in voltage mode and current control. Our customers should be able to change the supply voltage (Vbus), operating mode (voltage or current), wi...
L4985
 In my 750W PFC project, I've employed the L4985A PFC controller IC. I utilized the e-design suite offered by ST to design my PFC, and I fabricated the PCB using the components specified in the e-design file. Despite ensuring that all the necessary v...
kmpandav by Associate
  • 1661 Views
  • 3 replies
Resolved! LDL212 undervoltage mode
Hi, can you tell me what happens to the LDL212 when the input voltage drops below the output voltage+dropout? Does it track the input voltage (minus the dropout voltage)? Or does it drop out? Also, in the datasheet it mentions undervoltage lockout in...
ryanharm by Associate II
  • 2385 Views
  • 4 replies
  • 1 kudos
Steval-L99615C Request Refund
I have tried every possible option to get the discovery kit working. I am not satisfied with your technical support. How do I return item for a refund?
KWarr.1 by Associate II
  • 813 Views
  • 1 replies
  • 1 kudos
Why my STGIPS10C60-H has no output voltage
When using the chip GIPS30C60-H, sometimes the three-phase bridge switching signal is given but there is no output, regardless of whether the SD/OD pin is set high or not. This chip is used in a motor controller with a 0-270V DC bus supply and input ...
CSLx30 by Associate
  • 1021 Views
  • 1 replies
  • 1 kudos
