Ken-ken
I want use L6201PS.It has a heat pad under the chip. Should I connect the Heat pad to the GND? Or just leave it ?
  • April 10, 2023
  • 802 views
Best answer by Cristiana SCARAMEL
Hello @�?��? 岩原​ and welcome to the ST Community.
The slug (heat pad) is internally connected to the pins 1,10,11 and 20 (GND pins).
You can solder the slug on the PCB to improve power dissipation maximizing the ground layer.
_legacyfs_online_stmicro_images_0693W00000bi5S1QAI.pngLet me know if I addressed your concerns, if so please "Select as Best" label
Cristiana SCARAMEL
"If you feel a post has answered your question, please click ""Accept as Solution"""
Ken-ken
Ken-kenAuthor
I understand.
Thank you very much.
