2023-04-12 9:46 PM
I am designing a power metering circuit using the STPM34 IC, and I need to measure three channels of current. The STPM34 datasheet specifies that the device has two current measurement channels (IP and IN) and two voltage measurement channels (VIP and VIN). However, I require three channels of current measurement and am considering using one of the voltage channels (VIP or VIN) as a current channel.
The datasheet indicates that the voltage channels can be used as a differential input to measure the voltage across a shunt resistor for current measurement. However, this method requires a gain setting of 2x and may result in increased noise. I would like to know if there are any other considerations or limitations to be aware of when using the STPM34 in this manner.
Specifically, I would like to know:
Thank you for your assistance.
