Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! STWBC86 TX powers on and off every 4 seconds
Hi all, I designed a custom 5W charger around the STWBC86. I programmed the config and patch found in STSW-WBC86FWBPP to the IC using WPSTUDIO and I got it to charge my device (another custom circuit, this one using a TI BQ51050 receiver IC)... for 4...
Wireless charger with STWLC98
My question is about the STWLC98 chip. I am looking to integrate this chip into a wireless charger for a university project, so I need the source code of an application to be able to work on the chip and achieve my goal of making a wireless charger t...
DEIQO by Associate II
  • 1589 Views
  • 1 kudos
Resolved! STWBC86 FTP limit
Hi, Is there a limit of writings/erasings for the few times programmable memory of STWBC86?How many times should I expect? Best
STEVAL-WBC86TX - Transmitter restarting after EPT
Hi Once I send an EPT from the receiver device, STEVAL-WBC86TX disables its output, but after a few seconds it restarts automatically, even disabling repinging on the registers. The receiver device, once it sends the EPT command, it should shutdown i...
Resolved! STEVAL-CTM011V1A
Hi, I'm new with STM microcontrollers. I have several years programming Microchip PIC and develops with this other brand.I want to start a project with this Brand STM, then I bought a Nucleo F411. With this one I tried some examples an all worked fin...
PGinhson by Associate III
  • 1347 Views
  • 3 replies
  • 2 kudos
SCTHS300N75G3AG
Dear Sir/Madam,   We are planning to use this SCTHS300N75G3AG Sic MOSFET In our design.   We are not having any clarity on this component regarding to how much Copper thickness is required for this component and how to solder this component on the PC...
Resolved! VN5050AJ CS_DIS not working
We have a new design were we have multiple VN5050AJ high side drivers. We have connected all current sense pins together and want to enable just one current sense per time to save analog inputs. Now it seems that the CS_DIS pin is ignored and the chi...
rkager by Associate II
  • 2131 Views
  • 3 replies
L9963E accuracy calibration mode
Hello ST community! Actually my question is very simple. Is there anybody who worked with IC L9963E and used some calibration for more accurate Vcell measurement? I've found only mentioning in the datasheet about it. and in registers' section.But how...
