When Power Factor is changed, Current is changed in STPM34,STM32
Gyeongil-Kim
I use STM32 and STPM34. When the power factor load is changed , Current is changed about 1% in Metering..
Current increased in Lagging load.
Current is decreased in leading load.
The change is so small that I can't check current change in analog...
I wanna current is not changed. Can you help me..?
0 REPLIES 0
