STM32 MPUs Embedded software and solutions
Ask questions and find answers on STM32 microprocessors and dedicated embedded software solutions, such as Yocto SDK, Qt, and OP-TEE.
Default clock speed between STM32MP157-DK1 and CS42l51 codec, and how to change the clock from software to hardware and vice versa.
I'm using STM32MP157A-DK1 development board, in this we are using it for audio application,I'm porting stlinux in the board by yocto BSP.I wanted to know the codec(CS42l51) available on the board at what default clock it is operating and is it using ...
PSing.6 by Associate
  • 1548 Views
  • 0 replies
Kernel modules packages
I am building softwares for my cutom board based on STM32MP1 using OpenSTLinux. I get lot of kernel-module-* packages installed in the rootfs. I found they are build because fragment-03-systemd.config is added to kernel config if systemd is used.Can ...
PGE by Associate III
  • 1084 Views
  • 1 kudos
how to switch off lcd by using drm ?
i‘m not using qt or other 3rd gui framweork, no weston, no x, just direct use drm api,i need switch off lcd after some time is not operated,i google it a while,It looks i need a complete desktop environment to do that,so i want know is any way to do ...
Jzhua by Associate III
  • 3083 Views
  • 4 replies
stm32mp1 sgtl5000 codec over i2s
Hi All,i am getting kernel soc sgtl5000.c errorsgtl5000 0-000a: Error reading chip id -6any idea where am i missing , let me know if you need any further inputs&i2c1 {   pinctrl-names = "default", "sleep";   pinctrl-0 = <&i2c1__pins_a>;   pinctrl-1 =...
Ara.1 by Senior
  • 1219 Views
Resolved! Your STM32MP157 SVD file is highly incomplete and plain wrong at times. Could you please update it?
Hi ST!I am working with Rust on your STM32MP157. While we have this working already, this is cumbersome as we have to figure all register addresses and layouts manually. Normally, in Rust, we parse the SVD file corresponding to a chip and go from the...
NHues.1 by Associate II
  • 4651 Views
  • 13 replies
  • 2 kudos
