Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
L6480 PWM frequency (fPWM)
Posted on September 15, 2017 at 13:56HelloHow do I select the proper PWM frequency (fPWM) for a specific motor?I know how to set the Frequency in the driver but how shall I reason to get the optimal value?RegsBo#l6480
Bo Loof by Associate
  • 691 Views
  • 0 replies
SM30TY vs. STIEC45
Posted on September 12, 2017 at 17:51Hello, I would like to use in my design the Transil TVS STIEC45-28ACS and SM30T33CAY as the similar parts. One will be the second source for another. My question is: whether I can use one instead other and what a...
L6472 parameters setting
Posted on October 29, 2014 at 15:54Hi, I'm new to L6472 here, and from reading its datasheet, I think it would be a perfect fit to my application which will need to drive a NEMA34 motor to go relative high speed (such as 12 rotations per sec.).  I'...
sctisz by Associate
  • 2117 Views
  • 5 replies
What stepper driver should I choose?
Posted on September 08, 2017 at 23:33I am trying to figure out the best stepper driver to use for my stepper motor. The motor parameters can be found herehttp://catalog.orientalmotor.com/item/all-categories-legacy-products/tegories-pk-series-2-phase...
MX C409
Posted on September 04, 2017 at 20:48Hello, Can someone help me a lot if you tell me what is this component SMD MX C409.  I'm looking for more than a week on the internet and nothing of this component.  Attached photo. I need the datasheet of this c...
STL160NS3LLH7
Posted on August 17, 2017 at 07:06We have purchased 10 qty of STL160NS3LLH7 MOSFET IC. We found that Drain to source impedance of MOSFETs is varying( NOTE : MOSFET were not connected to any external circuitry while measuring impedance using DMM). Fo...
Question about Half-Bridge Output using L99MM70XP
Posted on August 08, 2017 at 12:15I am using L99MM70XP SBC.I have one question about Half-Bridge Output.Below Condtions, I think that All Half-Bridge output is Low (Open States)All High-Side / Low-Side Switch is Open. I think that PIN output Value i...
Remnants of stall detection in L6472 and L6482 datasheets
Posted on August 21, 2017 at 12:34Hiho,there are still remaining hints of stall/step loss detection (for example at the description of the FLAG pin) in the datasheets of the above mentioned ICs although they are only implemented in the L6480/L6470. ...
Blacbird by Associate II
  • 1514 Views
  • 3 replies
