Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Selecting SPV1040 for energy harvesting from solar cell
Hi,This is John from Qmax Systems, We are designing a product - energy harvesting from solar cell. Our application requires a boost converter to convert 0.5V to 4.2V with an output current of min 100 mA. Do you think LTC3105 will support this applica...
JFran.18 by Associate
  • 1118 Views
  • 1 replies
SPV1040 not working as specified in the datasheet
Hello. I am using the SPV1040 solar boost converter within the STEVAL-ISV012V1 development board. The datasheet states that the converter can work with an input voltage as low as 0.3 V. The solar cell I am using is able to provide 0.6 V (Voc) and 100...
paolus by Associate II
  • 769 Views
  • 0 replies
MTTF value of the following components.
Could you please provide me the MTTF (Mean Time to Failure) Value of following components. 1. TL431    https://www.st.com/resource/en/datasheet/tl431.pdf2. STM6720   https://www.st.com/en/reset-and-supervisor-ics/stm6720.html3. P0102BC     https://ww...
MPaha by Associate
  • 640 Views
  • 0 replies
LTSpice simulation for Viper26
Dears,I have found the Pspice model in your website, but I want to simulate it in LTSpice, could you please share another model or tell me how to change it to suit for LTSpice?​thanks�?Shanfeng​
sding by Associate
  • 862 Views
  • 0 replies
L9942 not working properly accoding to the sample
Hello  I'm a newer about  stepping motor IC L9942 I compsed of  L9942 Climate control Unit in HVAC .Some devices have no problem when they are controlled by a program.A specific device rotates discontinuously when it rotates.I am looking for the caus...
JHeo.1 by Associate
  • 707 Views
  • 0 replies
Where does VB come from in STEVAL-POE005V1 in RAUX-only mode?
Hello,I have a question concerning PM8805 and the related evaluation board STEVAL-POE005V1.From my understanding in the evaluation board the PGD signal is pulled-up by a resistor to VB.Now, when I power the board only by RAUX, where does the voltage ...
DLenh by Associate
  • 790 Views
  • 0 replies
Resolved! hall sensor reading problem
Hi I use a stm32f446 to run 2 BLDC motors (same motor, same configuration). One of the motors runs perfectly but the other one don't succeed to reach the speed reference. When I enter 1000 rpm it runs until around 200-300 rpm only and it makes a lot ...
Randy1 by Associate III
  • 1350 Views
  • 1 replies
