PowerStep01 application: Specify number of steps for RUN command ?
Hi,I have a question about the RUN command because there are different speed to MOVE command.In RUN command the speed min its 0,015 Step/second , in MOVE command the max speed min it is 15.25 Step/Second.I need run the motor at very low speed similar...
