Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
STSPIN32F0 12v internal regulator problem
Hi,I designed BLDC motor driver 12v powered card with the STSPIN32F0 chip and developed my own software. My codes run smoothly on the STEVAL-SPIN3201 kit.But on the own my card, 12v regulator outpus voltage inside chip didn't rised more than 1v.When ...
I've been trying to write my own code for a BLDC sensorless control. I've been having difficulty detecting bemf in the open winding.
My spice model looks good but in the hardware the bemf does not cross Vd/2. On some phases it is above Vd/2 and rising while on others its below Vd/2 and falling. I'm using a STSPIN230 as the triple half-bridge and am pulsing both the high-side and l...
BTrem.1 by Senior II
  • 609 Views
  • 0 replies
STEVAL-ISB043V1 documentation and software
Hello, we just bought two evaluation kits ST : STEVAL-ISB045V1 and STEVAL-ISB043V1.It seems impossible to find documents relatives to STEVAL-ISB043V1 such as document we found for STEVAL-ISB045V1 :UM2367 "Getting started with the STEVAL-ISB045V1 2.5 ...
Two LD29300 in parallel for increased output current
Hello,I'm trying to convert 20V/5A SMPS power to 19V for my noise-sensitive application. I couldn't find a good buck converter for my design.I came across LD29300 and saw that the specs except the output current meet my requirements. So I would like ...
BHan.1 by Associate II
  • 801 Views
  • 0 replies
Wireless charging coil selection
Hello.We are trying to develop a new product that will implement wireless charging technology and we are trying to follow the guidelines noted in the Qi specification. We have our eyes set on the STWBC-EP family.There are some considerations for this...
NEspi.1 by Associate
  • 724 Views
  • 0 replies
IHM06A1 STSPIN220 stepper motor is getting maximum current and there is voltage drop while stepper motor is in rest condition.
HelloI am intern and I am trying to control stepper motor by IHM06A1 StSpin220 stepper motor using STM32F401RE. When motor is in rest mode then there is voltage drop and STSPIN220 is taking maximum current and voltage becomes half with any motor. I a...
Rshar.11 by Associate II
  • 715 Views
  • 0 replies
Read actual voltages from STPMIC1
I'm reading the datasheet of STMPiC1 and I wonder if there's a way to read the actual voltages and/or currents. Not the setpoint ( = control registers) but the real voltages at one moment.
Mark81 by Associate III
  • 1038 Views
  • 1 replies
