Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
I use this IC as replacement of a similar IC. In the application I use the ZCD for a constant off-time circuit and also to disable the IC by pulling the ZCD high. This seems to be not working with this IC, as there are still output pulses generated.
Our Application is to dim the LED light using a dimmer circuit. PFA, The circuit design file and review it and if needed any changes let me know.we used BTA12 and MOC3021
In a project, my team is using the STGA1AS for the gate driver choice for several inverters. I see that this product is no longer recommended and is replaced by the STGA1BS. I reviewed the datasheets of both products but they are very similar.
The same Part Number: L99DZ100GTR, but one part marking is L99DZ100G while another is L99DZ100G AA. What is the difference between them? Are they both commercial samples?
If VN7140ASTR-E could be replaced by VN7140ASTR?what is the difference between them?
I am currently working on a motor control project development using STSPIN32F0251.Six-step control using HALL sensor, 48V power supply, working phase current is 11A. Then now running at 10A, the smartSD protection with the built-in gate drive is trig...
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
