Disable Vbus in both source/sink role during operation
Qmai.1
Hi everyone,
I am looking the way to disable charge and enable charge for external device wihin STUSB1602. I guest the register TYPE_C_CTRL 0x11 may help but don't know how to the way to do.
Does someone try that? Please help. Thanks in advance.
NBALL
Hello
Sorry but we are not able to understand properly your request.
Could you please explain a bit more what you would like to do ?
Qmai.1
Thanks for reply. Let's me explain a bit:
I have STUSB1602 connecting to CPU via I2C bus, use to charge external type-C device. My expectation is: I can stop charging if the system has some problem like over temperature, low power, ... And it can start charging again if system is good. I read the device document but didn't see the way to do. Please help.
