Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! STTH3010W thermal resistivity to ambient
I'm currently measuring the power loss of a 3 phase rectifier comprised of STTH3010W diodes.  I have my preliminary results obtained by measuring the voltage drop and current through an individual diode on my oscilloscope.  I'm just looking now to ve...
DBiro.1 by Associate II
  • 2254 Views
  • 3 replies
SPSB081-Component Datasheet
I am working on SPSB081 power management control IC. I need support in the following points:1. which revision of data sheet to be followed, because there are some discrepancies in register set(addresses) of revision 2 datasheet.2. for refreshing the ...
Crystal parameters for STPM32.
Posted on February 10, 2017 at 15:32Dear all, I need to know the range of the parameters (load capacitance, series resistance) allowed by the STPM32 IC.I didn't find these values neither on the datasheets nor on the applications. Can you help me?Tha...
VN5160S-E - 28V on INPUT pin, damahing my uC
HI all,Has anyone come across their HS switch putting voltage back onto the input pin of this device which is at VCC level (28V for me) so this is then going back to my microcontroller and damaging it. In what scenario is this even possible?Here is m...
SOP vs HSOP
I have some EOL components with two different part numbers, but I believe they are the same.  VND600SP13TR HSOP10 and VND600SP13TR SOP10.  What is the difference between the HSOP10 and the SOP10?
danm by Associate
  • 923 Views
  • 0 replies
L9963E
Hello!I am considering your L 993E for a new automotive BMS project. One of the biggest question marks is: why does it only have 14channels? We are aiming at 48V system but want to open for LifePo cells as well. Thats why we would need 16S /channels....
Orbiter by Senior
  • 984 Views
  • 0 replies
