Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
L9961 - not using VREG advice
Hi all,I am looking at using the L9961 (https://www.st.com/en/power-management/l9961.html) for a project and after looking at the datasheet, I see it has it's own LDO.The LDO can supply up to 35mA (pg. 13 of the data sheet). My design will use a STM3...
Electric heater control
Hello, I am designing Electric Heater control circuit. My circuit has two SCR in inverse-parallel strucuture and I use both of phase angle and zero cross control. I have used SCR component model BTW69, but the issue is that I need big heat dissipatin...
lhagva99 by Associate
  • 2010 Views
  • 1 replies
how to run and test single stand mastergain 4?
i am working on evlone65 watter .my pd charger not working i have use the st recommended pcb and components .there is any option to single run for test the mastergain4. if anybody have any idea then let me know please?
Resolved! stm32f429-disc1
How to turn on  stm32f429-disc1 board by using an external power supply and use stlink only for programming and debugging.
harry123 by Senior II
  • 1407 Views
  • 2 kudos
STEVAL-ISV019V1 and pv cells
Hi !I've the above eval board and wish to charge a 3.7V Li-ion 1500mah battery using PV Cells.When I connect the PV Cells to the input and check the output (bat-line), we do see 4.2V. Then when we connect the battery whose voltage is 3.98V and let it...
SMD unknown
I am trying to identify an SMD component, possibly a diode labeled:MEGP812
Florin1 by Associate
  • 1636 Views
Reach & Rohs for L7980TR
May I kindly ask you the Reach and Rohs documents for the following component: L7980TR? Many thanks & Best Regards
cannot find LED7708 / STSW-ILL035 GUI software
Hi,I cannot find the GUI software STSW-ILL035 which is the evaluation board for LED7708.The ST website does include a .zip file but it is only the Firmware and not the GUI software that controls it. This is NOT enough to get the evaluate using the ev...
farhangj by Associate
  • 1250 Views
  • 1 replies
