Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
ADP480120W3 gate resistance
HiDoes anyone know what the internal resistance value of ADP480120W3 module is? Or where could i find this data? The datasheet doesn´t show it.Thanks in advance
David_17 by Associate
  • 949 Views
  • 1 replies
STEVAL PCC009V2 & SPINFamily Evaluation Tool
Posted on April 04, 2017 at 17:31Hi,I am trying to use the STEVAL-PCC009V2 & EVAL6470H boards using the SPINFamily Evaluation Tool (Version 3.2)However when I try to connect to the board I get the following error:I have managed to locate the below h...
TDA7828 - what is that?
 Hello!Our company recieved from the official dealer in our country the TDA7828 chip. The seller claims that this is an improved version of the TDA7850, but we never heard about. Is it so?I did not find information about this chip on your site. Where...
l_ph by Associate
  • 2215 Views
Datasheet?
Hello I'm looking info about component. Please see attached picture. regards    
ule by Associate
  • 1028 Views
  • 1 replies
  • 1 kudos
Resolved! STEF01 SOA and reaction time
I have read the STEF01 datasheet looking for how STEF01 will respond to output short-circuit hard. After reading it I have no clue. What is the reaction time of the fuse to short circuit? Other vendos provide such informations.Second issue is that th...
DamianP by Associate II
  • 2002 Views
  • 3 replies
  • 1 kudos
Resolved! Why STEVAL-SPIN3201 not work without USB
Hi,I have kit STEVAL-SPIN3201 and now i have a expirience with controling my motor. But i never was able to start board without USB cable. It's seems like board need USB voltage for start microcontroller. So it can not start without USB. But if i the...
ARodr.12 by Associate
  • 2321 Views
  • 4 replies
Resolved! Boost converter using stw33n60m2.
Hi, I am designing a boost converter based on stw33n60m2, its 2.5kW 420Vout and 250Vin 5 amp Iout. the diode I am using is SIC schottky diode(very less reverse recovary). The issue is that I am facing mosfet failue at around 450v VDS (I dont observe ...
vasudev by Associate II
  • 1420 Views
  • 1 kudos
