STM32 MPUs Embedded software and solutions
Ask questions and find answers on STM32 microprocessors and dedicated embedded software solutions, such as Yocto SDK, Qt, and OP-TEE.
SPI Configuration issue
Hi,I am working on a project where the hardware platform is based on STM32MP157c and the OS is Linux 4.19.9 .I am facing on a issue about device tree spi configuration.Following SPI_overview on wiki.st.com kernel config has been modified with: CONFIG...
RBorr.1 by Associate
  • 4461 Views
  • 3 replies
I would like to run linux on cortex-M MCU in Stm32mp157-EV but i don't know what's wrong?
Hi dear engineers, i can run linux on stm32f429 mcu without any problem, but it failed on Cortex-M MCU in stm32mp157 board.After many hours i realize:error happens in below functionvoid __meminit __free_pages_bootmem...Anyone else had a similar probl...
Fheid.1 by Associate III
  • 4085 Views
  • 5 replies
  • 1 kudos
SPI1 hasn't clock on CM4
Hi, I use SPI1 and SPI4 in CM4 context on my custom board. Now, I use SPI_FullDuplex_ComIT_Master_CM4.elf binary to test those SPI controllers. The SPI4 is working, but the SPI1 doesn't working. Below is the log when SPI1 firmware started root@stm32m...
SChen.11 by Associate III
  • 2244 Views
  • 3 replies
  • 1 kudos
Invalid addresses of NVIC's registers in "STM32 Cortex-M4 MCUs and MPUs programming manual"
Hi,Section "4.3.11 NVIC register map" states that the base address of the main NVIC register block is 0xE000E100 and NVIC_ISERx registers starts at offset 0x100 (Table 49. NVIC register map and reset values). The same offset is given in section "4.3....
TPiła.1 by Associate
  • 1302 Views
  • 1 replies
  • 1 kudos
