Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
X-NUCLEO-IHM03A1 Arduino compatibility?
Posted on October 25, 2016 at 13:37Hello,I'm trying to use an Arduino UNO R3 to control the IHM03A1 stepper driver.  I found an Arduino library for the IHM01A1, which looks to me like an older version of the stepper driver.  I installed the library ...
Powerstep noise
Posted on July 10, 2017 at 17:33Hi, i'm trying the powerstep board, with 1/16 step using advance current control, when the motor run there's no problem. But when the motor is stopped there's a little noise from the motor. The noise is greather when ...
Triac T1635-700G-TR
Posted on June 16, 2017 at 06:46 I'm making about Triacs T1635-700G-TR to control motor, light. But I dont know detail about it. What is this IC integrated? I really need circuit about Using this IC. I'm read datasheet about this IC. But dont have c...
Firmware library for the L6482
Posted on June 28, 2017 at 18:17Hello, I've been using the L6482H discovery board and have got it to work ok. Now I want to control my EVAL6482H board with a nucleo F072RB board but I'm not sure how to proceed.I tried to download the STSW-SPIN005 fi...
VND5T100 - Reverse polarity protection
Posted on December 14, 2016 at 07:23Hello,I have made the reverse battery protection according to the datasheet and the UM1557 (user manual) with a diode in the GND line in parallel to a 4.7kOhm resistor.But if I do a reverse supply I detected a hig...
smiller9 by Associate
  • 3367 Views
  • 6 replies
Resolved! Overcurrent threshold of VND drivers
Posted on July 03, 2017 at 13:00I am documenting short-circuit behavior of the VND5T050AK.  I remember seeing a threshold around 36-44 A as the trip point to put this chip in the overload state.  However I can't find any spec in the data sheet and c...
ECU injection drive chip
Posted on July 03, 2017 at 05:12Hi,I want to get the datatsheet for the ATIC39-B4 ECU injection drive chip and also New ECU injection drive chip.Please send me the datasheets. (mailto:hshmicro7@daum.net)Thank you for your hospitality.soohaeng hong /...
stability analysis of A7985A
Posted on June 28, 2017 at 18:06Hi all,I find some troubles to perform the stability analysis (Gain margin, phase margin) of the regulator A7985A with the tool eDesignSuite.If you have any information that can help I will be grateful.Regards,Omar.
Omar Dya by Associate
  • 706 Views
  • 0 replies
Remaining Time in STC3115, Error.
Posted on June 27, 2017 at 14:35Hello everyone,I would like to ask a question about a problem with the integrated STC3115.I apologize first if the question is displayed incorrectly or implicitly.I've read some examples including the STSW-BAT001, but...
Using L6599 STBY pin for power output control through PWM
Posted on June 26, 2017 at 14:37Hi, I'm trying to design an LED driver using L6599 and L6533 (boost then LLC) stages, I'd like to know if I can use a 300Hz PWM on the STBY pin of 6599 to drive the output in a PWM dimming control? The datasheet doesn...
