Fault Ack in Firmware
s61331
Posted on January 11, 2017 at 09:17
how can i reset a fault in Firmware?
i tried MCI_FaultAcknowledged(oMCI), but it doesnt work.
with friendly greetings
Eric
s61331
Posted on January 26, 2017 at 16:09
Hello, this problem is solved.
Iam not sure wether its the only solution but it worked for me.
if(MCI_GetOccurredFaults(oMCI)>0){
      MCI_FaultAcknowledged(oMCI);
      TB_SetUserTimebaseTime(10000);
      start=TRUE;
if (TB_UserTimebaseHasElapsed() && start){
      MCI_ExecSpeedRamp(oMCI,target_speed,duration);
      MCI_StartMotor(oMCI);
      start=FALSE;
The time can be shorter.
Greetings
Eric
