Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
B-g431b-esc1 vs steval-esc001v1
Hello all, I would like to understand the key differences between the two controllers and which one would better suit my needs. ​I want to precisely control the speed of two sensorless bldc motors, keeping them in sync regardless of the load each of ...
Hannibal by Associate
  • 784 Views
  • 1 replies
Resolved! Using STEF01 as a high-side switch
Hi,I'm planning to use STEF01 as a high-side switch plus an external MOSFET for blocking inverse current from load. Is this feasible or I would be wrong?gaston
Gaston by Senior
  • 1121 Views
  • 1 kudos
Resolved! ALED6001 eDesign dimming setting
Hi Sir,​ALED6001 eDesign show BJT is as the red rectangle.However, most PNP BJT is show as below picture.I search some data, they show exchanging BJT's E and C, BJT can work. However, the hfe will decrease and the BJT cannot afford high voltage.Below...
TSU.11 by Associate II
  • 1177 Views
  • 1 replies
Resolved! L6482 step-clock mode
Hello,I am designing a stepper motor controller with L6482.The choice of L6482 was made because of its integrated dual h-bridge gate drivers and relatively high voltage rating.The chip features nice set of motion commands but due to specific demands ...
PKrak.1 by Associate
  • 1516 Views
  • 3 replies
