Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
VIPER16LN thermal shutdown happening in 2mnts at 3.75W
Hi Team, we are using VIPER16LN in one of our project. we are facing thermal shut down happening within 2mnts time. the below are the testing conditionInput voltage: 230VACOutput Voltage : 15VOutput current: 250mABut viper16LN can handle around 6W po...
SRedd.6 by Associate
  • 818 Views
  • 0 replies
having trouble getting the motor to run at a consistent speed
I am working on a project that involves controlling a DC motor using a microcontroller. I am having trouble getting the motor to run at a consistent speed and it keeps stalling. I have tried adjusting the PWM signal and playing with the circuit but n...
amuha.1 by Associate
  • 926 Views
  • 0 replies
What are the versions of STUSB4500?
Hello,While having a look at NVM flashing example, I came across those lines:I2C_Read_USB_PD(0,DEVICE_ID,&Buffer,1); // DEV_CUT 0 : 1600 , 1 Reserved , 2 : 1602 , 3 Autorun   if(Buffer & ID_Reg >= CUT) { if ( nvm_flash(0) == 1)   prin...
JulienD by Senior
  • 906 Views
  • 0 replies
How to drive StSPIN32G4's Gate
I spent a long time trying the following three methods, but still failed to drive the grid successfully.​1. I checked Google and found that there was no information or tutorial about it. Then I found a situation similar to mine in the forum. I just...
0693W00000Y8oiAQAR.png 0693W00000Y8oitQAB.png 0693W00000Y8onUQAR.png 0693W00000Y8oo8QAB.png
Szhen.11 by Associate II
  • 2233 Views
  • 3 replies
