Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
I am using STCS1APHR constant current LED driver but at the time of powering ON the supply,Led blinks (turn on ) momentarily need a solution on that...
Hello,I am using STCS1APHR constant current LED driver.CASE 1: I pull up Enable pin to VCC and pull down pwm pin to GND with 10K resistor.CASE 2: I pull Down Enable pin to GND and pull down pwm pin to GND with 10K resistor. But in both cases the l...
Apati.19 by Associate
  • 1298 Views
High-Side Switch VN9004AJTR circuit and program design
High-Side Switch VN9004AJTR is fairly new, so nothing on the web to help with circuit and program design. It has a simple default circuit and MCU programming configuration, but it has some nice features that require more complex programming. Has any...
DCyr by Associate III
  • 849 Views
  • 0 replies
