Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Resolved! LED1202QTR
Hello ST Team,We are observing that LEDs are minor glowing, during turn off condition due to leakage current. As per our application we are not not using any PWM configuration for LEDs. We are just making LEDs turn ON/OFF as per application requireme...
kadam by Associate II
  • 1199 Views
  • 1 replies
L9963E
Hi, I am MURALI SELVAM from India, We are plan to build the circuit for Battery Monitoring circuit for which I select L9963E so someone give me suggestion for ensure L9963E part number is suitable for my project, My battery spec is "6S 25200 mA/h so ...
murali by Associate III
  • 920 Views
  • 0 replies
Resolved! Reverse Recovery Time Trr of new FERD rectifiers family ?
From an ST newsletter I understood that ST is promoting new FERD diodes as "rectifiers for switching power supply". I could use these new diodes in a new flyback design so I downloaded a couple of datasheets and searched for Reverse Recovery Time Trr...
USB Device Not Recognized for STBC08PMR
Hello,On my custom designed PCB, there is a USB port for battery charging and programming ESP32 microcontroller. When I plug in to the PC, I get "USB Not recognized" message. In addition, the two LEDs are light up. In the datasheet of the charger IC ...
AE104 by Senior
  • 1183 Views
  • 1 replies
Resolved! STEVAL-ISV020V1 increase VEOC
Hi @Peter BENSCH can you help me how to modify the  STEVAL-ISV020V1 to make the VEOC up to 5.3V?
rsmqu by Associate II
  • 1709 Views
  • 3 replies
Resolved! WBC86TX and WLC38RX inband communication
Hello everyone,I have the STEVAL WBC86TX and RLC38RX evalboard here and I am currently testing them with the STSW-WPStudio.In my application I want to implement an custom inband communication between RX <--> TX. It seems that there is the possibility...
simonh by Associate III
  • 1945 Views
  • 1 replies
  • 1 kudos
