STM32 MPUs Products
Resolved! Key format for secure boot
Hi, I'm trying to generate secure boot keys using native linux tools. I assumed the secureboot format would be documented, but all I found was links to STM32MP_KeyGen.I can use openssl to generate ECDSA keys, and also get publik keys out. I am at teh...
mrnuke by Associate II
  • 708 Views
  • 1 replies
Resolved! No wlan0 on DK1 I just received.
I have a pair of DK1 boards I just received that I wanted to get working with wifi direct, but neither even can show a wlan0 interface. In the past I have used a DK2 with buildroot and got the wlan0, and a coworker used stock yocto build on the DK2 a...
BillR by Associate III
  • 612 Views
  • 1 replies
NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
Hi:​Anyone familiar with this issue?When I plug in the network cable, the following information will be printed later:​[ 373.607360] ------------[ cut here ]------------[ 373.610551] WARNING: CPU: 1 PID: 0 at net/sched/sch_generic.c:447 dev_watchdog+...
Wjian.1 by Associate II
  • 3466 Views
  • 6 replies
DK1 examples list?
Hi is there a list, or sorts, with the examples that should work for the DK1 dev board from the DK2 examples?
OHaza.1 by Associate III
  • 340 Views
  • 1 replies
How to investigate the cause of the Fault Reports.
I use STM32MP151CAA3 Cortex-M4 on my custom board.I got fault report from uVision debugger when __main called in my startup assembler code.​https://www.keil.com/support/man/docs/uv4/uv4_cp_m347_faults.htm​Memory Manage Faults DACCVIOL (Data access vi...
HMasu.1 by Senior
  • 826 Views
