Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
STC3100 with Arduino
Dear ST-Fellows,I'd like to use the STC3100 with the Arduino IDE but my knowledge is too little to get it working. I looked at the libraries provided here:https://github.com/st-sw/STC3100_GenericDriverCould you please tell me how to adapt the files t...
MBobi.1 by Associate II
  • 884 Views
  • 0 replies
How to Avoid OverCurrent Error using STSW-SPIN3204 Library ?
I am using STEVAL-SPIN3204 development Board & using STM motor Library STSW-SPIN3204 .I am using a Maxon Motor with 12V DC input voltage.I am successfully able to run motor at 14k RPM but when I try to run motor at 25K RPM , my motor stalls & hits ov...
ASing.41 by Associate
  • 973 Views
  • 0 replies
Resolved! STEVAL-STSPIN3202 eval board not found on OSX
Hi,I have a STEVAL-STSPIN3202 evaluation board and trying to setup the environment on MacOS. When I plug in the eval board with a USB B cable to my MacBook, I don’t see a device in both ls /dev/tty* and ls /dev/cu*No devices even when I do, ioreg -p ...
VChan.2 by Associate II
  • 3064 Views
  • 3 replies
Is it necessary to use heat dissipation on PowerSTEP01?
I´m using powerstep01 in a new design. I need to keep a little holding current on the step motors (3 motors).I noticed that the chips get hot even the board is on open air. I´m afraid that when mounted inside the product cage, the chips get very hot....
AMast by Associate
  • 2275 Views
  • 1 kudos
