Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Where have all the powerStep01's gone?
Where have all the powerStep01's gone? The stock of the chip and even the Nucleo boards on every online site except eBay have run out. They all say zero. Has there been some sort of mass buy or did ST recall the product?
Kurtnelle by Associate III
  • 1341 Views
  • 3 replies
Resolved! EVAL6498L - what type of heatsinks can be used?
Hi thereI am planning to use EVAL6498L to build a boost dc-dc converter with synchronous rectification. I notice that if I fit two TO-220 switches these will be very close, therefore I am not sure what heat-sink I can use, as mechanical space becomes...
Lello by Associate II
  • 1171 Views
  • 1 replies
Resolved! Can someone identify this IC?
This is an Power Management IC but I can't find it's datasheet or Part number with all my search, Could you help please?
ANass.1 by Associate
  • 1073 Views
  • 1 replies
Resolved! EVAL6498L - how to connect it to the microcontroller?
Hi there, I am a first time user of the gate driver evaluation board EVAL6498L, and I am trying to understand how to connect it to the controller and to the MOSFETs, I am using this document .Assume I am sending 2 PWM signals from a microcontroller P...
  • 2810 Views
  • 3 replies
IHM08M1 - Issues with the Over Current Protection (OCP)
Hello all, I am developing a position control for a 48V BLDC motor here. The hardware I'm using is an IHM08M1 motorshield and a NUCLEO-H743ZI2 microcontroller board. Since I use the Ethernet functionality of the Nucleo board (and the RMII has overlap...
JSteg.2 by Associate
  • 3355 Views
  • 3 replies
Resolved! STEVAL-ESC002V1 and STSPIN32F0A 2S configuration
Hi,we implemented your reference design coming from the STEVAL-ESC002V1 that is suitable for 2S to 6s battery.We found that the circuit didn't work under the 6.5Volt and we have the confirmation of this out of spec because STSPIN32F0A is working from...
FRagg.1 by Associate II
  • 1744 Views
  • 3 replies
