Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
4 arms half-bridge symmetrical converter design
We want to control a 4 phase variable reluctance machine. For this we need to make (or buy) 4 arms half-bridge symmetrical converter with the following characteristics:Max current of the DC bus: 62 AMax DC bus voltage: 25.2 VMax PWM frequency: 30 kHz...
YSAAD.1 by Associate
  • 1027 Views
  • 1 replies
Strange description in datasheet of STPMIC1
In p. 28 of Datasheet - STPMIC1 - Highly integrated power management IC for micro processor units, 4.2.1, it says:3. Manually by setting VOUT[4:0] field of Table 38. BUCKx_MAIN_CR or Table 43. BUCKx_ALT_CR registers. Refer to Table 9. LDO output volt...
STNS01 specification
Hello, I am considering the STNS01 for a new project. The datasheet seems wrong. Is it possible to have power on SYS when starting with BAT, so with IN disconnected?How much is the maximum current flowing from IN to SYS?Thank you
lukin by Associate III
  • 638 Views
  • 0 replies
How to downlod the firmware of 3-phase Vienna rectifier with low cost mixed-signal control for power factor correction in microcontroller ? Please give all steps.
Hi,I have downloaded the firmware ("stsw-viennarect.out") for the 3-phase Vienna rectifier with low cost mixed-signal control for power factor correction from the ST's website.Could you please give me the all steps for download this firmware in micro...
KPate.8 by Associate
  • 889 Views
  • 0 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
