Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
ST1S06xx Fixed voltage application schematic
I have a fixed voltage version of the ST1S06xx, but I am struggling to make it work as there is essentially no information on what the Vo pin does, apart from "output voltage in fixed voltage version". That is the only mention of the existence of the...
EGoul.1 by Associate
  • 1086 Views
  • 1 replies
Resolved! STPMIC1 Clock Stretching
Hi,is it possible to use the STPMIC1 on an I2C Bus where another slave does clock stretching? In the datasheet it says that the STPMIC uses the SCL to shift data. For my understanding the clock strechting of the other slave shouldn't bother the STPMI...
Fee by Senior
  • 2079 Views
  • 4 replies
Error limit in phase calibration - STPM34
Hi, We are using the STPM34 in one of our products.We are facing a problem with phase calibration. Every time we try to execute the calibration process we get an error bigger than (+1) or smaller than (-3). According to the datasheet, the formula of ...
TMaga.11 by Associate
  • 665 Views
  • 0 replies
Software driver support for L9788 and L9396
For the devices mentioned above, i couldn't find related software drivers to be used in the host MCU, only datasheets available.for L9788 , even the datasheet doesn't have any information regarding control and configuration of the IC.I am planning to...
Datasheet for the L9788 Multi functional IC
Hi, I am interested in prototyping with the L9788 multi functional IC. However I am unable to find any documents which has detailed information about the IC, apart from the basic datasheet. It is possible for me to get the necessary documents for thi...
NBula.1 by Associate III
  • 645 Views
  • 0 replies
  • 2 kudos
External battery STM32 power shield
Hi, I want to ask a question. I have STM32 power monitor shield and is it possible to measure current without powering the device by the shield? I want to use battery to power the device and measure the current drown from battery.
MKoro.1 by Associate
  • 711 Views
  • 0 replies
Resolved! Hello my name is Vicente I work un CONACYT MEXICO and am Electronic Engineer Actually I need Reliability Information of some components. No,part SMB6F70A STTH1R06AFY STMicroelectronics LM2904PT STMicroelectronics
The Reliability information consist in MTBF/MTTF or FIT of each component with a base temperature and Reliability test information.Thank you for your helpbest regards
GPere.21 by Associate II
  • 1623 Views
  • 4 replies
