Problem with IDE
Grzesi3k777
I've got problem with STMCubeIDE. You can see my problem at photos I attached. Can anyone help me to solve this problem. I try to work on Lenovo Legion 5 with Ryzen 5 5600h and RTX3060. Second graphic card is integrated with Ryzen CPU.
This problem is at lot of windows at MX section when I try to configure my STM. I try to open this program with both graphic cards. I have latest drivers to both graphic cards. Try to standalone MX software but still same result.
Maybe someone had similar problem.
18 REPLIES 18
Grzesi3k777
Hi Herve,
Thank you a lot for answer. I will check it and of course give you feedback.
Grzesi3k777
Hello again,
I tried it but I still have same problem.
Today I updated my graphic cards drivers. Tried to set to work with integrated card only and second attempt to start with dedicated card only and still same problem. I cannot learn more but I really want
Grzesi3k777
Hello again,
any new suggestion how to solve my problem?
Grzesi3k777
Hello, is anybody here?
jepp. but maybe same, as with my problem...
(cannot be reproduced , so no way to find out (for STM) whats the problem)
see here:
https://community.st.com/t5/stm32cubemx-mcus/cubemx-ui-is-messed-up-again-again-and-again/td-p/580741
seem to be same problems - no solution by STM.
just try: using only one screen. ( and/or maybe font size..)
Hi, thank you for share this link. I see that no one can help with this mess. It is impossible to work with it.
Are there any alternative to configure STM like in CubeMX? I don't want to work on registry yet.
did you try with only one screen setup ?
try CubeMX for configuration of cpu.
https://www.st.com/en/development-tools/stm32cubemx.html
maybe (!) its working...
I have CubeMX and CubeIDE installed but both have this weird problem
