Other: hardware
STR912FW44 VIC power up issue
Posted on August 12, 2013 at 09:15I'm trying to use VIC module on STR912FW44 and when I try to write to it's registers, it seems like it's unresponsive - nothing changes. I had no issues getting TIM0 to work, but no success with VIC.I set the gating...
GPIO_APP DATA Registers configuration
Posted on August 13, 2013 at 07:11Hi, Currently I am working on a spear 600 board on which i am booting an RTOS over it.Currently i am trying to write a GPIO driver for the Application GPIO's which are 10 in no. I am not able to figure out how to c...
a23 by Associate
  • 397 Views
  • 0 replies
ST7FLITE29 Write Protect
Posted on July 30, 2013 at 12:08Hi I have a new build PCB with a ST7Flite29 fitted, I cant program the device, I have had to run an external clock signal to Clk In (PB4), the programmer is now reporting ''Write Protected'', how do I get this back, t...
ST7540
Posted on March 11, 2013 at 16:26Hi, i use the ST7540 and got the problem, that the demodulated bits are shifted sometimes, because of first bit is lost. How can i solve this problem? And where can i find more information about extended control regi...
crused by Associate
  • 361 Views
  • 1 replies
how to trace the reason of hardfault
Posted on July 23, 2013 at 06:27Hi all,I am getting hardfault exception in my code. And when i watched my registers CFSR and HFSR their values are likeCFSR = 0x00001100   - IBUSERR = 1   - STKERR = 1HFSR    - FORCED = 1So can you just tell me what t...
manoj23 by Associate II
  • 302 Views
  • 0 replies
ST6 Controller Toolchain or IDE
Posted on July 22, 2013 at 08:28Hello,  i would like to download the ST6 Assembler-Linker Toolset (PN: STSW-ST6005) from your internet location. Link : http://www.st.com/web/en/catalog/tools/PF257578 But unfortunately there is no file to download. I...
ST7-EMU3 Windows 7 Compatibility
Posted on July 03, 2013 at 07:28Hi, We are trying to interface ST7 EMU3 with a Windows 7 laptop but we get communication error. ST7 EMU3 connects with a XP laptop with no issues. Are there any environmental variables to be defined to make ST7 EMU3 t...
Microcontroller
Posted on April 30, 2013 at 11:55Hello: I am new to microcontrollers, old time programmer, Fortran, PL1, machine code. Would like to control a 50w shaded pole motor including an rpm sensor to stabilize speed. Can you suggets a microcontroller I coul...
bkalaska by Associate
  • 308 Views
  • 1 replies
