Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Identify this part?
Edited to place the image in the post - for easier viewing.Hello, This is my first time posting. I am trying to find the P/N from the part's marking. If you know it, please let me know.Engraving: GP229Guess: Schottky barrier diode STPS2L60 - 2A, 60V....
CXTURBO by Associate II
  • 254 Views
  • 8 replies
Resolved! STPMIC with STM32H7B3VIH6
I've designed a custom board and, I'm writing my own firmware that controls STPMIC.While writing a general-purpose driver library to enable future use in other hobby projects, I ran into a few questions.my own general-purpose driver library is: https...
jaehoon by Associate III
  • 427 Views
  • 4 replies
  • 2 kudos
STSAFE-A110 - Local envelope Key
Hello,I am trying to integrate an STSAFE-A110 chip into my product for keys/data securely storage.The communication with the chip works fine (approved by simple command as echo or generate_random).So I tried to generate a key in a local envelope key ...
Resolved! ECMF02-2AMX6 GND connection
Techsupport ignored my request, so I have to come here. The part is ECMF02-2AMX6. It is CM choke plus ESD surge protector for USB2. Here's the question: in the datasheet from June 2011 Doc ID 17815 Rev 2, this is the recommended layout is shown (see ...
morzh by Associate II
  • 156 Views
  • 6 replies
  • 2 kudos
Identify this component ?
Hi I have a diode which i believe is a zener diode as the marking on the bottom line is zthe 3 lines are as followtop line=  st and a 6 at the endmiddle line= CU6bottom line= z 721i need to know what diode it is and what voltage and current value it ...
ryjord88 by Associate II
  • 218 Views
  • 4 replies
  • 3 kudos
