Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
[Short Survey] Please give us your feedbacks on ST model Zoo Services
Hi everyone,   In order to help our developers understand how their work is used and what to do in order to improve model zoo, we kindly ask you to look at this survey about ST Model Zoo Services.   Link of the survey: https://docs.google.com/forms/d...
Can not add signal from usb (serial)
Hi everyone,I am using version 4.5.0 of Nano Edge AI with the STEVAL-PROTEUS1 sensor kit. I am trying to implement anomaly detection for motor vibration. However, when I attempt to add a signal using USB (serial), I occasionally receive meaningless 1...
Batuhan35 by Associate II
  • 1425 Views
  • 1 replies
MCU/MPU Selector for AI
In CubeMX I have installed the AI package. After that I go to "Start My project from MCU" then I go to "Middleware" then "Artificial Intelligence" and Enable it.Here, I select whatever model and click Analyze. The button becomes grey, but I don't get...
syalam by Associate
  • 2803 Views
  • 3 replies
sparse model
I have a large PyTorch model that I pruned using unstructured methods to decrease its size. The model size can only decrease if I filter out the zeros and save the model in a sparse format.However, my problem is that ONNX doesn't support the sparse f...
audi by Associate II
  • 2831 Views
  • 1 replies
Problem with "train.py" file ModelZoo
When I try to launch the "train.py" file, in conda virtual environment it gives me an error "ModuleNotFoundError: No module named 'logs_utils'". This is a module called on the code line 23 of the train.py. After that I've proceed with a "pip list" to...
Diogomv by Associate
  • 3747 Views
  • 4 replies
Implementing custom post processing for different models
Hi,Is it possible to add the custom post-processing function in the middleware of the object detection application https://github.com/STMicroelectronics/stm32ai-modelzoo/tree/main/stm32ai_application_code/object_detection?Thanks! Reply
ai studio serial emulator no input file support
It's a shame that the serial emulator in AI Studio only supports a COM port as input and not an offline .csv file of recorded data, as it's not always possible to have access to a live stream.I've noticed as well that the COM port options don't seem ...
GMeta.1 by Associate III
  • 1517 Views
  • 1 kudos
Resolved! NanoEdge AI integration
Hi,I am a research intern working on edge AI for anomaly detection.I am trying to integrate my anomaly detection NEAI model with a Network Management Card project which is in C++(cpp) running on STM32MP1.I would like to know the possibility of integr...
mpeton by Associate II
  • 4300 Views
  • 7 replies
  • 1 kudos
