Error unknown nature on STM32Cube IDE after update
‎2020-12-17 7:04 AM
Hi all, how are you?. I'm making a project with an STM32F401VE and I've updated the IDE, after that there are about ten dependencies that says something related to inknown dependencies and the .ioc project doesn't opens. I read some over there and some other people had the same problem after the STM32Cube IDE was updated, currently for me is showing this problem with the version Version: 1.5.1, Build: 9029_20201210_1234 (UTC).
I tried also to import the project or creating a new project but the behavior is the same. How could this problem be solved?
In the meantime I will simply reinstall the IDE
STM32CubeIDE
STM32CubeMX
STM32F4 Series
‎2021-01-15 7:34 AM
My stm32cubeide 1.5.1 crashed after upgrading from the application (not able to build, "nature" problems like Johnny )
After uninstalling and installing 1.5.1 from scratch, I was able to build projects (imported and converted from old workspace)
After installing eGit, the problem came back again
‎2021-01-18 2:15 AM
i have the same problem with EGit and version 1.5.1.
When the plugin is installed stmcubeide crash.
i try reinstalling but it doesn't work.
Can anyone tell us how to solve it please.
‎2021-01-18 2:28 AM
ST has finally published 1.5.1 installers on www.st.com: STM32CubeIDE - Integrated Development Environment for STM32 - STMicroelectronics
Did you still get issue relying on it ?
Which OS are you relying on ?
‎2021-01-18 2:28 AM
‎2021-01-18 2:38 AM
last friday i downloaded that installer .
i installed it from scrath and the problem persist.
Im using Windows 10
‎2021-01-18 2:48 AM
I'm using Windows 10. I already used the 1.5.1 installer on Friday
‎2021-01-18 2:59 AM
The problem here is about the JRE version.
STM32CubeIDE embeds Java8 while, because of a 3rd-party installation (eGit, etc...), an indirect core dependency is updated and depends on Java11.
How to solve it
Notice: STM32CubeIDE has not been entirely validated on Java11, I strongly suggest to keep a backup of the jre folder.
- Download Java11 from AdoptOpenJDK, binary archive not installer (https://adoptopenjdk.net/archive.html?variant=openjdk11&jvmVariant=hotspot)
- Go to STM32CubeIDE root directory and rename jre/ to jre.backup/
- Unpack Java11 archive and rename it to jre/
- (good practice: report any troubles you could face with Java11 on ST Community, but clearly state that the JRE version is not the default)
‎2021-01-18 3:26 AM
thank you, this work for me
‎2021-01-24 11:05 PM
Thank you for the great support!
Sorry, next time I will check the ST Community first.
:thumbs_up:
‎2023-07-30 1:48 AM - edited ‎2023-07-30 1:49 AM
I have a similar warning: "Unknown referenced nature: fr.ac6.mcu.ide.core.MCUProjectNature"
I am unable to apply the fix as per @Julien D.
STM32CUbeIDE root has no jre/ subdirectory in my case (Windows10 64bit professional)
Current version (directory name 1.8.0 is remanent of first install)
