STM32 MPUs Products
Is it possible that PMIC NVM is changed accidently?
Hi all ~We're using STM32MP157C MPU + STPMIC1A for my custom board with ecosystem 4.1We've completed almost all of development for hardware and software. And we just made a sample of 30 units. Unfortunately, we've found some issue in specific 3 units...
Resolved! SDK MPU installation script error
Hello,I would like to setup environment for STM32MPU according this instruction:https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-DK2/Develop_on_Arm%C2%AE_Cortex%C2%AE-A7/Install_the_SDKso I downloaded the SDK .tarhttps://...
ZHala.1 by Associate II
  • 2827 Views
  • 6 replies
  • 1 kudos
Peripheral example for STM32MP135f-DK?
I am familiar with the STM32 MCU:s and now I try to learn some around the Linux MPU:s.I am looking for a simple pheripheral application example on how to control e.g some GPIO:s from inside Linux using the STM32CubeMX and STM32CubeIDE.Any hints?Thank...
DSI DISPLAY DOES NOT WORK AFTER ESD EVENT
Hi,I have working on STM32MP157C-DK2 Board and after application of 8KV ESD strike on USB Shield, the DSI Screen Goes off completely (Discharging on Ground only). To verify the issue I have applied the same strike on a custom board consisting of STM3...
DKUMA.11 by Associate III
  • 2328 Views
  • 7 replies
stm32mp157d-dk1 starting coprocessor from bootloader
Hi,I have an stm32mp157d-dk1 board, for which I am building the core-image-minimal image within the poky (Dunfell) distribution. Other than adding the "meta-st-stm32mp" layer I have not made any ST related customisations.I am trying to launch a custo...
cubeprogrammer_fail.png flash_issue_from_st_example.png file_list.png correct_fw_name.png
mjuels by Associate III
  • 900 Views
  • 0 replies
Resolved! Yocto mickledore SIGN_TOOL
HelloIn the new version of Yocto release mickedore, SIGN_TOOL variable needs to be specified to sign TF-A binary which should corresponds to STM32CubeProgrammer signing tool https://wiki.st.com/stm32mpu/wiki/Signing_toolPractically, how can we set th...
syedelec by Associate III
  • 2740 Views
  • 6 replies
  • 1 kudos
What if M4 RAM is too small?
When porting applications from single core M4's equipped with FLASH, the RAM associated with M4 in MP1 is supposed to cater for both RAM and former FLASH needs. It won't fit. How to overcome this if M4 code/data size cannot be reduced?
PeterL by Associate III
  • 1320 Views
  • 5 replies
