2023-07-09 05:42 PM
I bought two same board and use one to test.
After upgrade stlinux on this testing board, the cpu it can recognize is only one when the other one can recognize it two.
could you give me a guide to fix it and why this happened?
Thanks.
2023-07-11 01:48 AM
Hi @MJo.3 ,
I also notice difference in OPP_MODE
So I'm wondering if you have same software version embed in the 2 boards
Can you share boot logs of each boards ?
Olivier
2023-07-11 01:48 AM
Hi @MJo.3 ,
Olivier
2023-08-11 01:36 AM
I checked software version and it's not same.
I upgrade the os, and it works
